Repair and disassembly information for Samsung's Galaxy A13 Android smartphone, released in March of 2022.
Samsung Galaxy A13 (SM-A136U) Power Button Replacement
I need to replace the power button on my Samsung Galaxy A13 (model SM-A136U), but I can't find a specific guide or a replacement power button part on iFixit. The button is not working. Has anyone else had this issue or know if the power button is part of another component? Any advice on how to proceed with this repair would be greatly appreciated.
I had to replace mine and after dropping the phone a few times had issues with it again. Take Sim card slot out and open carefully (ribbon cable is attached from button to board). Take out screws of top plastic piece and gently pry up the clips on side. There is a little metal piece that sits over where the ribbon cable attaches to the board. I have had to pull that out and slightly bend it inwards because the cable wasn't making good connection after dropping it a couple of times. After I did that it worked fine for quite a while. I still have to replace the power button again though because it finally failed. Hop this helps.
I didn't find a guide for the SM-A136U, but the Spanish site Nadie Me Llama Gallina has one for the SM-A137. Given they both fall under the A13 model number, I suspect there won't be much difference between them. Anyway, here's how to replace that fingerprint sensor/power button.
Manuals / Samsung Galaxy A13 SM-A137 / Fingerprint and Power Sensor Flex Cable - Nobody Calls Me Chicken
As you might guess, the site is written in Spanish, but if you use it with a browser that includes a translator like Chrome, the guide works just fine no matter what your native language is.
P.S., A little research shows the A137 is a 4G phone, while your A136U is the 5G model. I still maintain there shouldn't be major differences in the procedure between the two.
Thanks, will give it a try.
westdr1dw crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 99
crwdns2942667:0crwdne2942667:0 426
