Investigating "emergency calls only" / 0 SNR
I replaced my USB / headphone jack board ("sub board") because of problems with the USB-C port.
Now, the USB-C port works well, but the phone struggles to get a mobile network connection. Indoors, both manual and automatic network selection fail (automatic: "emergency calls only", manual "Couldn't connect"). Outdoors, I get a 4G LTE connection, but bandwidth and jitter are poor, and I get 0dB SNR reported by the Network Survey app.
My guess is that there's a problem with the antenna cables.
Things I have tried so far:
  • Reseating both ends of the coax antenna cables (white and black)
  • Inspecting the cables, the PCBs, and the antenna cable connectors for damage
  • Changing network mode to "NR/LTE/GSM/WCDMA"
  • Reverting to the original sub board, to try to rule out a problem with the new board
Does anyone have any suggestions what else I could try?
This is the replacement part I used: https://www.ebay.com/itm/285156938467
And this is the guide I was following for disassembly and reassembly: https://www.youtube.com/watch?v=Ue6e6FOL...
One thing I noticed is that the replacement board is slightly different to the original – there's an additional antenna port on it (labelled "L8"), and there's seemingly a microcontroller missing vs the original. Is it possible that there are different hardware revisions here?
