Issue with GSP 600 Volume Control – Left Ear Crackling/No Sound
Hi all,
I’ve been having an issue with my GSP 600 headset for the past month. The volume control has started acting up—touching or turning it causes the sound in the left ear to crackle or cut out completely. I could usually fix it by turning the dial back and forth until I found a “sweet spot” where the audio worked normally.
Unfortunately, the issue has now gotten worse. The sound from the left ear has completely disappeared. However, it does come back temporarily if I press down on the volume control really hard with my finger. Oddly enough, I can also get it working if I play audio at a very high volume using a volume booster—but only as long as I don’t move my head at all.
I’ve seen some guides for older Sennheiser models where you could bypass the volume control entirely by soldering a few wires together. The problem is that the PCB in the GSP 600 looks different, and I’m not 100% sure how to proceed without damaging it.
Here is one of the guides for the PC360
https://www.diyaudio.com/community/threa...
I’ve also added a photo of the PCB. I’ve managed to identify most of the connections:
- LHB-SN
- LHB-SP
- L-HB
- R-HB
- G-HB
These are five small pins grouped together.
There are also two larger wires, but I can’t read the labels clearly because they’re covered in glue. One seems to say something like R-SP..., and the other likely starts with L-SP..., possibly left and right channel connections.
