Can I interchange parts 2 MacBook models
From a MacBook 17” unibody-A1297 and an 13” mbp- A1495. One doesn’t turn on and the other gets a file with a question mark. I was hoping I could Frankenstein them and make one that works.
First off the A1495 is the battery P/N not the system and is from a MacBook Air from (2011-2014) which would be incompatible with your older 17" MacBook Pro 17 A1297. Some parts from within the A1297 are interchangeable (not all). Here's a full listing for reference A1297 Systems
The 17" I bet needs a new battery as it's likely not turning on.
The MacBook Air may also need a new battery just based on its age, but until you repare the OS install (replace the drive?) it would be hard to tell.
If you messed up on the model try using this EveryMac - Lookup or just go to the systems listing to scan through EvereyMac
Louis Loving-Montgomery crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 48
