The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
Power on couple of seconds power off
My nieces x box one has a fault where it powers on for a couple of seconds then off again so I figured it might be a hard drive issue, replaced the hard drive and it seemed to work it booted up asked me to update unfortunately I didn’t have the controller at the time so waited for her to drop one off by the time she did the issue had returned, checking around the board for possible shorts I come across I believe are the RAM chips I have a photo so correct me if I’m wrong the caps around these chips majority of them are short to ground can anyone tell me if this is normal if not what are the possible causes I’ve heard that some components are supposed to be but not practically all of them the other set under these are the same
Hi!
Usually this is caused by the PSU or MOSFET.
Those are the ram chips located in your photo. Are they shorted there only??
I would also check the MOSFET and measure the PSU! Just to be sure.
@dan0 Thanks for the comment to be honest as soon as found it was shorting around the RAM I came on here to ask but I will check the MOSFET and check back in once I have thanks again buddy
No problem! Please keep us posted. RAM chips could be failing and maybe need a replacement as well.
Mike crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 55
