Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
MacBook Pro wont charge after battery replacement
I finally changed my macbook pro's battery with an ifixit replacement after mine had the "service" warning showing for a while. I did the install and the calibration. But noticed it kept switching from charging to plugged in but not charging. I reset the SMC and it kept doing it. I dig diagnostic and shows normal. I went in and unplugged the battery, held down the power and turned it on with only power from the power supply connected, turned off, plugge dbattery again and turned on. It works for a bit but will eventually go back to plugged in but not charging. Not sure what to do as this was not an issue with the original battery, even tho it lost charge quickly.
Are you monitoring the battery temp? The battery won't charge if the battery is too hot. This is a safety feature, stop and active programs, take a snapshot of CoconutBattery, put the system to sleep letting it rest for a few hours or over night wake the system give it a few minutes and run CoconutBattery again is it charging now and the temp lower?
Hernan Diaz Montalvo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 52
