Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
What are the Micro components by the HDMI
While replacing a HDMI port on my PS5 I managed to desolder two micro components that are right next to one of the legs of the hdmi luckily they didn’t go far so soldered them back on but when I put the new hdmi on I again accidentally knocked the smaller of the two off and lost it and the other is looking damaged can someone please tell me what these two components are so I can buy replacements
@mike79997 add some images of what you have going on there. Your description alone will most likely not lead to solution. Use this guide Adding images to an existing question to add the images
If I am interpreting your description correctly, likely this is a Diode and a resistor. But as you can see in the image, there are a few components in this area (and some on the other side of the board too). Usually the one that gets moved is the little capacitor very close to the port. I attached an image below.
If these are the ones you mean, the one marked A6 is the diode (its often listed as an A6 or C1 diode in a SOD323 package), you can probably find replacements easily because this happens a lot.
The smaller one is a 27Kohm resistor. I am not sure of package size off the top of my head, but I can probably find out.
Interpreted perfectly Your a Legend thank you yeah it made me feel better finding out it’s a common problem and I’m not the only one 😆trying to train myself not to be so heavy handed thanks again really appreciated
Mike crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 93
