Repair guides and support for the Willys-Overland CJ-3A "Civilian Jeep," manufactured from 1949-1953.
Why wont my jeep start
points and condenser have been replaced the coil too but when turning over there iis no fire power to the coil
crwdns2889612:0crwdne2889612:0 -1
Susan Luntsford, you did not tell us if it is stock or if it is a mod jeep. Engine Size and mods are important since it does make a difference. If you have no power to the coil, check your ignition switch. Make sure the switch close the circuit to the ignition coil. Check the wiring from the positive terminal of the battery to the switch, make sure it is connected and not shortened out. If it worked before, but stopped working since you replaced the parts, double check your work.
Susan Luntsford crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 3,232
