Honda presented the 2011 Odyssey Concept in early 2010 at the Chicago Auto Show and officially on June 17; with a larger, wider body, a lower roofline and revised styling. A Touring Elite model became available.
Rear wheel and axle problem
I got quoted $3k for "rear sub frame new arms with toe adjustment cam bolts" for a 2018 Honda Odyssey. Is this a serious problem besides uneven wear on the wheels?
Unless the bushings are worn, which is unlikely, theyre probably quoting the arms because the cam bolts are seized into the bushing so the alignment cannot be adjusted, meaning the tires will wear unevenly, but shouldn't pose a safety concern. However, if theyre quoting the subframe with it, that usually indicates that its rotted out and can cause potential safety issues if it let's go while driving
Jian Xu crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 8
