Repair guides and documentation for the Google Pixel 6a with 5G smartphone. Released in July 2022.
Can I replace screen after water ingress?
Unfortunately, I accidentally submerged my Pixel 6a for a few seconds - about 10 minutes later the screen went completely black. The next morning, I tried restarting to no avail. The phone vibrates when connecting the power cord, so I suspect the screen itself has bit the dust.
My question(s):
  1. Can I replace the screen even after water ingress?
  2. Are there any signs to look for inside the phone that would determine a screen replacement would be futile ?
  3. Will I not know if a new screen will work until I physically plug in the new screen?
I recently backed up media on the phone, so if I need to replace it entirely, so be it.. But I'd rather replace just the screen for the sake of saving money, if possible!
Thank you for any and all help!
Hi @pixeluser1234
Here's a link that shows how to check if the LDI (liquid damage indicator) has been activated which shows that a liquid has entered the phone and most likely has caused some damage to the systemboard. Scroll down and select Liquid or Corrosion evidence.
If the LDI has turned pink then water has entered the phone so the phone would need to be opened, inspected and cleaned before you would know whether a new screen would be needed or not.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
Do not try to charge or to turn on your phone anymore and then remove the battery as soon as possible from the phone to minimize any further damage.
After this you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Google Pixel 6a repair guide that may help.
If you determine that the screen does need replacing, there's the ifixit parts list in the screen replacement section of the guide, that shows the cost of the screen (with tool kit and without)
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Pixel_user_1234 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 31
