Why does my jeep not shift gear like I could bel
I cannot shift my gears in my Jeep manually like before
Update (06/09/25)
It started when I left my keys outside my vehicle and was able to reach inside and unlock the door when I did the alarm went off I hooked the battery found my keys and it's not been up to shift right since
Update (06/09/25)
Well I've not seen my answer yet so I don't know what I'm doing wrong here
Be patient, Duane, this site is primarily manned by volunteers who aren't on the site 24/7, so it may take a while before someone who knows the answer to your question gets a chance to see it and possibly do some research into what may be wrong with your Jeep.
I suggest you unmark your own answer as the chosen solution; many people will see that in the listing and assume you've already got an answer and don't need their help.
Why my 2005 Jeep Cherokee Laredo will not shift manually it seem to all started when I responding through the window to unlock the door when I unlock the door the alarm went off cuz I couldn't find my keys found my keys finally but I turned the battery off till I found my keys put the battery back up it's not been shifting yet
@duane16496
Try disconnecting the negative battery cable from the battery for about 30 minutes, then reconnect it and see if everything now works OK.
Have read that doing this resets the PCM (power train control module).
It may have glitched when you "...turned the battery off..."
Duane crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 137
