Blown chip in position D7700, unknown value
I was working on my MacBook Pro, when I decided to reconnect the right fan, since it had been unplugged for making a rattling noise. I lubricated it, and yet it still felt just a bit stiff. When I turned on the computer with it plugged in, it took a push to get it spinning, but it seemed to work. Then, smoke comes out from under the logic board. The component I find to be blown is in position D7700, but I do not know what kind of component it is (I assumed that it was a diode, since the position started with D), or what value. It is a small rectangular chip, with two legs on the left and right on the bottom, and one leg on the top that is centered. Amazingly, the rest of the system still seemed to be working, including the USB port and the optical drive. Also, the system booted and I was able to install El Capitan. So, what component could this be, and at what value?
Hi! If you could add some pictures of the damaged area to your post, it may help others identify the damaged component.
@wozmon you should at least identify the logic board by its 820-XXXX numbers. D7700 turns into a needle in a haystack without the proper board number. Help us to help you by supplying as much information (logic board number and images are best) as possible.
@wozmon the only D7700 I can find in all of the boards that the device you picked, is on a 820-2132 logic board. That particular diode is part of the FW supply. It is a SC-59 signal switching diode. Looks like it is available at Mouser.com, Digikey.com as well as many other places.
Thanks so much! I just wanted to know, if this component is blown, how likely is it that other components are also damaged? I inspected the components in the general area, and didn't see any visual damage.
@wozmon really hard to say but not very likely. It is possible that something got shorted out or the Diode itself failed. Fairly easy to replace the Diode and then re-evaluate.
Great! I ordered ten of the part from DigiKey, so if it blows up again I have replacements.
Bad news, the blast from the diode package seemed to be what caused two of the three solder pads to lift off the board. I tried to run bodge wires from other points on the same trace, but this only resulted in further motherboard damage. Unfortunately, it's dead. Thank you so much for helping me identify that component, though!
_nec6678 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 49
