Stripped screw is stuck, what do I do?
I was trying to open up my 3DS ie open up the shell, not the backplate, but it had stripped screws from the previous owner. When I attempted to unscrew it, it was simply to dug out from my tinkering. I tried the traditional unscrewing methods such as increasing friction like rubberband, super glue(I tried, but the issue is that there's good chance it will just fill up the screw hole so I tried to avoid putting too much), but it did not work. I attempted a drill, and now there's a hole through the screw yet there is somehow still tension making it worse with no way to grip it. Is there any way to open it up? I would be fine if I had to order a bottom shell casing, but I would rather salvage this one or at least get it off without forcing it. The two stripped screws are the bottom right corner and top left side (if we consider the shoulder buttons pointing up). I was very dumb. I appreciate any suggestions.
