The Milwaukee M18 2606-20 is a 1/2" Compact Drill Driver with two speeds and a clutch adjustment.
Gear box reassembly - chuck spins very slowly
Hey all,
I picked up and old used cordless drill ( model # 2606-20, 18v 1/2" driver). It was essentially free, part of a small lot of drills I bought for cheap. So I wanted to clean it up, see if it worked (it didn't have a battery), etc.
I found a battery and confirmed that it did work. Generally it all seemed decent - at least functional.
I took it apart, cleaned up various things... including disassembling much of the gear box section (not all of it, but say 2/3). When I reassembled things... and figured out that the magnet ring was backwards :) ... I tried it out. The motor spun, the shaft spun... but the chuck was spinning very slowly. Like I had turned a gear increaser into a reducer. So say 10-20 RPM instead of... ~450.
So I took it all apart again, this time disassembling the entire gear box and including the chuck assembly... put it back together - still turns very slowly.
I have reviewed various disassembly videos and some assembly diagrams... I think I'm doing it right.
I know it can be really hard to troubleshooting something like this without seeing it, without really knowing what I did... I'm pretty handy with tools and things (spent 15 years working as a maintenance technician in a wafer fab) - so not a complete noob. But nearly always the first time you do something it's not perfect - I'm missing something here, obviously. :)
Anybody have any thoughts about what I messed up?
wd40 since you mentioned its old open assembly spray with wd40 and clean all moving parts .
Thanks for the suggestion. I have been cleaning and lubricating the gear assemblies and other moving parts as I have been dismantling and reassembling things, though. The issue seems to be in the gearing - because the motor shaft is spinning at what (I think) is the correct RPM, but the chuck spins very slowly.
JFixIt crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 100
