Is there a software to bypass the ring silent control?
I droped my iPhone & my silent mode switch is broken it is blocked on silent mode
Here's an application that will bypass your silent control: http://iPhonepackers.info/AutoSilent.htm
+1 Cool! That's useful.
If such software exists, I can guarantee that Apple does not sanction it. You may be able to find a solution if you jailbreak your phone.
sounds like a good idea but I'm unable to test it right now I'm facing problem with cydia it is quiting when ever i want to launch it, it looks like i have to re install it first thank u any way for the tip
cydia?
Cydia is the jailbroken app catalog.
I think that Cydia's quitting is documented right now- I believe they are working on a fix with the repos.
i too had this problem a while ago with my iphone 4. after spending days around forums and all i almost gave up. but then accidently i came across the ringer/silent sbsettings toggle. nd it definitely saved me a %@*@ lot of money.
solution is if ur iphone is jailbroken, go to cydia.if not, jailbreak and install cydia.install sbsettings thru cydia. and after u have installed sbsettings, search for ringer/silent sbsettings toggle. it wil work miracle :)
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 7,488
