Repair and troubleshooting guides for air conditioning units used in houses, offices, and cars.
Why does my wall thermostat go off and blank the screen?
Wall thermostat on HVAC in US intermittently powers off and goes blank. Shortly after the AC turns off. After a few minutes the thermostat powers back on and the AC unit starts and appears to work OK.
Hi @rtolleson
What is the make and model number of the air con unit and thermostat (if one used didn't come with the air con)?
@jayeff I've posted an answer: the original reason I asked the question. It's a Rheem unit with a Honeywell thermostat but as I understand it this solution will apply to many models.
The Problem
  • Symptom stated is likely a clogged drain from the central AC coils in the attic (it's called the evaporator coil condensate drain)
  • The drainpipe from the evaporator coil in your attic unit will have a small reservoir with a float switch in homes newer than 15 years old. when the drain clogs and water backs up and fills the reservoir, the float switch will open the 24-volt circuit powering the thermostat; the thermostat will go blank on many models.
  • When a slow drain empties that pipe, the reservoir float switch will return to the unclogged (drained) state and return power to the thermostat; the thermostat then powers up and works normally.
  • This drain and float switch described above are in the PRIMARY drain routed to your home plumbing drain: often to a sink drain or similar. The large pan below your AC unit is an EMERGENCY drain to catch drained water when both the primary drain AND float switch described above fail to drain or detect a problem in the drain. This emergency drain pan should be dry if this float circuit is stopping the AC unit due to the clogged primary drain. The primary drain needs to be unclogged, or water damage can to your home can occur if you rely solely on the emergency drain (which usually drains to a pipe dripping outside from the eave of your house. Simply disabling the float switch and relying on the emergency drain is unwise.
The Solution
  1. Check that the sinks etc in the vicinity below and near the AC are draining properly after running a few gallons of water through the sink. You will often find a slow drain in the home that, if unclogged with a household drain opener, wll suffice to drain the AC unit.
  2. Use similar drain cleaner to clear the AC drain pipe. There is usually an open pipe above or near the float switch to pour in a small amount of the drain cleaner. Avoid getting that strong product on the float assembly else it may be damaged.
  3. Plugging the open pipes (including those to the inside of the AC unit, and blasting with compressed air may clear the drainpipe. Don't try this until the pipe has completely drained and any drain cleaner has been flushed from the system. Those chemicals cause skin burns.
  4. Once the pipe is draining freely, begin an annual early Spring routine of treating the drain with 1 cup of a 50-50 solution of vinegar and water to protect the drain from algae: the likely original cause of you clogged drain.
A lot of AC units do not drain into sink.drain lines. Least not where I'm at. They're usually routed outside via a 3/4" PVC drain line. I never use drain clog chemicals on these. I either blast with CO2 or I go to the outlet with a wet/dry shop vac and suck the clog out. A cap full of bleach also works wonders for the algae, as does a cap full ice machine sanitizer.
@brandon_k Good information that applies to millions of homes.
Randy Tolleson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 113
