The Sony DualSense Edge (CFI-ZCP1) wireless controller was released in January 2023. It features replaceable joystick modules and other upgrades from the DualSense.
change joystick to tmr, but stick drifting
ive changed the joystick/analogy stick to tmr sticks in the dual sense edge, but the right one moves by itself to the left
Attach screenshot of the calibration screen, the left one calibrated fine but some reason the right stick does this drift to the left. Id appreciate if anyone can help or guide on the issue thank you
Similar problem, installed Genfull sticks, the right stick does not work at all, and the calibration is the same picture.
Have you solved your problem? If so, how?
Have you taken it apart again? In my case I could have put it in with the wrong screws or something easy like that.
yes only one screw in it
I’m having stick drift also. Tried recalibrating, then went back in and re flowed solder. No help. May remove totally the replace
Same issue, i tried 3 gulikit sticks. The third one lasted about two hours then hard left.the 4th stick is good calibration is still good.
Going to try hallpi sticks next.
matt91 crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 201
crwdns2942667:0crwdne2942667:0 912
