Shorted positive terminal and no crank
have a 07.5 Chevy Silverado 3500 HD with the lmm motor and I had blown the head gasket due to a plastic heater hose connector and drove it for a year before it finally gave up and I had it fixed 5400 bucks later after a 3100 dollar qoute and when I got it back it ran but not like I would have hoped but better than it has ever run. Only problem. Was the key swith was messed up more than it was when I gave it to the. Which I wasn't mad about but after replacing the switch and key cylinder I had to do the theft relearn and it started right up and no problems til the granny clip on the collar blew out and lost all my fluid and I fixed that and I forgot to mention when I got it back the 4 we selector wasn't working but it was driving so I figured fix it later. Then later came I got a clinking noise like hard shift coming from. Transfer case and after replacing a bunch of stuff it ended up being the range fork was worn out so I replace transfer case up and running again and the selector started working after I did the relearn. And now my current issue is engine power reduced and scanner said it was manufactures control which I believe comes from a clean particulate filter and I have had the issue since I bought the truck. BTW I bought it with 300k on it and now it has 375k. So I was miss in the second cat on back since I bought it so I hollow out the one in front a weld new pipe and muffler without other cat and was only able to get one of the 02 sensors back in and the steel tubing I cut off I just connected together with a hose. So it's missing one o2 sensor. So I got the idea to take the inner cooler out and clean it it because it blew the hose off on the driver's side leading into the cooler. I figured it must have been stopped up and so I cleaned it with a kerosene and washed it out with dawn and water and let it dry thoroughly before putting it back together and in the process I took the battery out on the driver's side and so I could get the reservoir out and the positive cable fell over and shorted to the engine for only like 4 or secs before I took it off and re secured it. So I finish up everything and go to start it and everything powers on and will not crank. So I jump solenoid it cranks with no start. I then go to scanner and it powers up with no communication. I check all fuses. With tester then pull every one and do a visual and no blown fuses battery is charged on both sides and still nothing so I disconnect batteries and try a reset still not turning over. So any input would be gratefully appreciated”
Refine your
I forgot to mention no security light when key is in run position and the only prior codes were o2 temp sensor codes which is expected
My word, I feel like I'm having an anxiety attack after reading that!
Did you check your fuses, especially any located in the engine compartment?
All fuses fuseable links and charged batteries for good measure
