The Google Pixel 7a is the budget-oriented variant in the Pixel 7 series. Released in May 2023, the Pixel 7a improves upon the Pixel 6a with face unlock, 8 GB RAM, heavily upgraded cameras, and wireless charging.
Screen displaying, but touch dose not work.
Hi ,
My screen is displaying fine, but touch is not working. It happend after the phone fell an landed flat on the screen, it dident even crack the glass. A small protion of the low end of the screen is working. Is it the screen itself that needs replacement or is it connector issue / motherboard issue?
Thanks for all help in advance.
Although it wouldn't hurt to check the connector, you're almost certainly looking at needing to replace the screen. It's unlikely to be something as simple as a connector that's come loose, as the display connector on your phone is held down with a metal plate and a screw, so they virtually never come loose even as a result of a fall.
Even though you don't see any visible sign of damage, there are delicate connections between the flex cable and the glass that the digitizer circuits are printed on, and a sharp shock such as a fall can easily be enough to disrupt those connections. Unfortunately, once they've broken loose they can't be reconnected so the only solution is to replace the screen.
Here's the guide you'll need to do the job; if you want to support iFixit's repair efforts you can buy the screen right here on this website, but if you're more cost conscious you can easily find them on sites like Amazon, eBay and AliExpress.
Google Pixel 7a Screen Replacement - iFixit Repair Guide
That should be everything you need to get your phone working again; good luck with it and be sure to come on back and let us know how it all turns out!
I'v orderd a new screen. Thanks!
Did a new screen end up fixing the issue? I have a Pixel 7 that displays just fine but doesn't respond to touch at all, and am wondering if a screen replacement is likely to fix it.
its probably a digitizer issue. since on the 7A they are infused it will result in the enitre screen being replaced
Tusk crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 199
