The Lenovo IdeaPad Flex 5-1470, manufactured in 2017, features a 14 inch touch screen display which folds 360 degrees into a 2-in-1 convertible laptop. Model Name: 80XA Model Number: 80XA0001US
Why is the charging port not recognizing the charger cable?
When the charging cable is plugged into the charging port, the laptop doesn’t recognize the cable and doesn’t charge.
@karrinavaldez first you want to check your power supply. Make sure it has the proper voltage. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question
To work on this use the guides Lenovo IdeaPad Flex 5-1470 from here. Or you can use the hardware maintenance and service guide for that. You will find that on the same page under the Documents heading
Karrina Valdez crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 53
