The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
Only the fan turns on but no power
Whenever I plug in my xbox to the power supply only the fan turns on but the power switch doesn't respond. There is no activity when i touch the power button on the xbox.
Actually, my original power adapter for the xbox got burnt and hence I was using an atx pc power supply to power it. One day somehow two of the wires came in contact with each other and something was shorted, ever since then the fan powers up to full speed as soon as the power supply is connected but nothing else responds on the xbox.
My xbox360 S console turn off after 5-6 minutes of playing games
My power adapter will automatically turn from green to yellow causing the console to off automatically then after like 2 minutes it comes on and off on and off continuously
How do i get rid of this problem i have disconnected the power adapter from the Xbox and reconnected i have also changed wall sockets. Problem still persists
Anant Singh, sounds to me like you are having power supply problems. The reason why your fan comes on is probably due to the fact that your 12V is still working, but your probably lost the rest. Check all the connections with a multimeter and check the switch first, make sure it works properly, after that check the voltage on the power supply. Checking the wiring will be a little tougher since you modded your Xbox. Check the PSU for blown Caps and fuses. Good Luck.
I have the same issue. I'm using a atx power supply and fan turns on and there are no lights on anything. When my glitch chip was attached the light would come on for that but still no response fro m the console. Iv e tried multiple power supplies as well. Any ideas?
Maybe it's the 5volt pin problem, also I have a problem that my Xbox keeps giving me the 3 flashing rings, it is not overheated, is it because the atx power supply I use is just cheap? Also whenever I stop the atx power supply fan, and keep it running, it works fine, so what is it, also could a 12 volt and 5volt 2amp power brick work, I tried it but it gives me the red flashing rings, pls help
So was the consensus that the old ATX PSU died? I've done the same thing with an Xbox one, worked fine for about a week or two and now I just get nothing at all unless I manually turn on the PSU with by shorting the PS_ON line to ground, when I do that though I get full fan and no ability to turn the Xbox on, it just makes an attempt at the on sound but doesn't actually do anything from there. All my voltages are reading correctly, but I can't seem to measure amperage in any capacity. I guess I'll jury rig another PSU to see if it's the issue. Was a cheap one from the road side anyway.
Anant Singh crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 9,508
