Right joy con not charging after replacing analogue stick
Some months ago I had joy con stick drift on both joy cons and as the mechanic that I was i tried to fix them and the left one i successfully changed the stick as well for the case of the joy con with a transparent one that looks very nice and when I was about to close the right joy con i realized that it wont charge i knew it still work cuz it was 100 % when I changed the stick and for 4 days it worked until the battery died so now I think I need some help in fixing them (I might have a suspicion that the fuse might be to blame for the joy con not charging because I didn't have the plastic tweezers at the time) so if you have ideas please don't hesitate to tell me. Or to bypass the fuse
[image|3652722]
[image|3653522] idk it just doesn't load
Hi!
Please check the comment below (from my answer).
Thanks!
Hi!
Could be. Could also be the rail which failed. The only way to know is to replace and test. Bypassing the fuse is possible (direct solder connection) but is not recommended at all.
If you can share some pictures with us regarding the ribbon cables and motherboard, that would be great!
No it's not from the rail I just change them both with new ones thinking that might have been the problem
Alright. Did you checked the fuse with continuity test? Also, the picture is not uploaded. Here is how to do it: Adding images to an existing question.
Thanks!
Popa Rațiu Alexandru crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 73
