My Screen Backlight won't turn on after a hinge repair
1st things to mention are:
(1) What I did before my backlight won't turn on is I try to disconnect my IO cables from the IO board but fails due to the fact I'm trying to fix my hinge in my laptop since it is wear down and also I accidentally turn on my laptop when doing so. the next thing I did is...
(2) I disconnected my laptop's battery to avoid the accidental turn on of my laptop. By the I'm done fixing my laptop hinge, I'm aware that my edp cable is slightly tuged when I'm assembling back my laptop...
(3) Edp seems fine I guess? and I already check it with my multimeter in continuity mode... Though I'm skeptical since I lack the knowledge how to fully use a multimeter...
Note: One thing to mention is I have done the fundemental backlight repair in youtube like refreshing the graphics software and disconnecting and reconnecting the cmos battery, I'm not sure about my lcd screen but on the other hand I haven't check the fuse in my Motherboard...
Please help me fix my problem, I don't want my dad to find out since I'm a CSS student and I desperately need this machine in college.
Hi @enricogabr24424
Turn on the laptop and try shining a flashlight at an angle close to the laptop's screen and check if you can see any images on the screen at all.
They will be very faint if they are there so trying this in a darkened room may help.
If there are no images to be seen, try connecting an external monitor (TV?) to the laptop's HDMI port and check if the laptop displays on it OK. Don't forget to operate the appropriate function keys to switch the display to the external monitor.
If there is no display on the external monitor then there's a problem on the motherboard that needs to checked further. For this you will need the motherboard schematics. (see below)
If there are images to be seen then there's a backlight problem with the laptop screen.
Since it seems that you didn't disconnect the battery from the motherboard first thing before doing anything else inside the laptop, (is this correct?) you may have accidentally blown the backlight fuse on the motherboard.
I can't find the schematic for the motherboard (is it an NM-E341, printed on board?), I don't know which fuse it is or where it's located on the board.
There's this video for another IdeaPad 3 15 model that may or may not help, as it shows where the fuse is located. Worth a look perhaps if the laptop is open.
If you want to be sure, there's this website that has a download for the NM-E341 boardview (tvw.zip file) and schematic (Rev.01 pdf) files but you have to join to download from them, (and possibly pay??, I don't know as I didn't try).
Yep, there's a display can be seen in the monitor and also the external works just fine. It's kind of irritating that I didn't know this earlier about the battery. So just a fuse replacement only? Anyway, thanks for so much for quick respond and people like you are needed in my generation more... I'll update if there's more to fix
Enrico crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 100
