The HP Elitebook x360 1030 G3 is a 13.3" two-in-one laptop released in 2018. This model name can be found on the underside of the laptop in "Project Name."
Replacement screws for the battery and bottom cover
I have none of the screws to secure the battery, SSD, or bottom cover can someone help me figure out the screws and what size and etc is
Hi @zachwheele17833
Here's the maintenance and service guide for the laptop, that gives some sizes for the screws you need.
On p.26 it shows the specifications for the 4 screws that hold the base cover but not for the captive screw that is also used.
On p.27 all is says it that there are 5 Philips head screws used to secure the battery, 4 are the same but the other is a broad head screw. Unfortunately, no specifications are shown. You could always use a straightened out paper clip to measure the depth of the screw holes to at least find out what length they need to be
On p.30 it shows the specifications for the single screw used to secure the SSD drive.
If all else fails you could search online for the screw kit for the laptop. Search online for L34182-001 to hopefully find suppliers that have it in stock as most don't. Be aware that the kit contains every screw that is used in the laptop
Zach Wheeler crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 70
