Released September 16th, Apple's "smaller" flagship smartphone features a 6.1" ProMotion OLED, a triple-lens rear camera system, 5G, and a newly designed "Dynamic Island" around the front-facing camera and top sensors. Successor to the iPhone 13 Pro.
Will the phone remain waterproof after replace battery
After changing battery will the phone email waterproof
That's a good question! Generally, when a phone manufacturer designs a phone to be waterproof, they use seals and adhesives to protect the internal components from water and dust.
However, opening the phone to replace the battery can compromise these seals. Even if the battery replacement is done carefully, it's very difficult to guarantee that the original waterproof seal will be perfectly restored.
Therefore, it's likely that the phone will no longer be truly waterproof after a battery replacement. It might offer some level of water resistance, but it's best to avoid exposing it to water or liquids to prevent potential damage.
If maintaining the phone's waterproof capability is crucial for you, it might be worth considering professional battery replacement services that specialize in maintaining water resistance, although even they might not be able to guarantee it completely.
Depends on the glue you use
If you use enough glue with a high quality, it will remain water resistant (not fully water proof)
Get something from aliexpress, then if you knock a jug of water over then your phone is probably done for
Does you kit provide the glue to make the iPhone 14 pro water resistant again?
It won’t be ‘waterproof’ again. I’ve never seen a waterproof Apple phone yet but have seen plenty of water damaged ones. The only way to get factory resistance is have Apple do it.
DrJBS crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 167
crwdns2942667:0crwdne2942667:0 553
