Remove back cover for SAMSUNG 4K Curved TV (UE65KS9500T)
Hi,
Can someone guide me how to open the back cover of my TV? I need to replace the backlight. All the videos on YouTube show that the TV's supposed to have hole where I need to lift up the backlight cover. But my TV doesn't have that.
I have screws along the buttom but no hole.
Someone have video that I can see how to open the back cover?
Hey there! It sounds like you're diving into a bit of TV surgery to replace that backlight. It's a bummer when the videos don't quite match your model.
Since your Samsung UE65KS9500T has screws along the bottom but no obvious access hole, the removal process will likely involve taking out those screws. Here's a general approach that often works for TVs with this design:
  1. Unplug and Prepare: First things first, make sure your TV is completely unplugged from the power outlet. Lay it face down on a soft, clean surface to protect the screen. A blanket or towel works well for this.
  2. Remove the Bottom Screws: Carefully unscrew all the screws you see along the bottom edge of the TV. Keep these screws organized so you know where they go when you reassemble.
  3. Check for Other Screws: Sometimes, there might be additional screws hidden in other places, like under stickers or around input/output ports. Take a good look around the entire back panel to make sure you haven't missed any.
  4. Start Prying Gently: Once all visible screws are removed, the back cover is likely held in place by plastic clips. You'll need to gently pry the cover away from the main body of the TV. You can use a plastic spudger or a thin, non-metallic tool (like an old credit card) to work your way around the edges. Be patient and avoid forcing anything, as you could break the clips. Start at one of the edges or corners and slowly work your way around. You might hear some clicking sounds as the clips release.
  5. Lift the Back Cover: Once all the clips are free, you should be able to carefully lift the back cover off. Be mindful of any ribbon cables that might be connecting the back cover to the internal components. If you encounter any, detach them gently before fully removing the cover.
Important Considerations:
  • Static Electricity: Be mindful of static electricity, as it can damage the delicate internal components. Consider using an anti-static wrist strap if you have one.
  • Documentation: If you still have the TV's manual, it might contain specific instructions on how to remove the back cover. It's always worth checking.
  • Online Forums: You might find specific discussions or videos related to your exact TV model (UE65KS9500T) on online forums dedicated to TV repair. Searching there could provide more tailored guidance.
Take your time and be gentle, and hopefully, you'll have that back cover off in no time to get to the backlight! Let me know if you run into any more snags along the way. 😊
@vedangupadhyaya while AI can be a useful tool for some things, us moderators here at iFixit do not feel it can be relied on as a sole authority for answers to repair questions. So while we won't remove your answers , we would strongly request that you indicate that your answer is generated using AI so our users can judge the accuracy of the answer for themselves based on that knowledge.
Matan Siman Tov crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 62
