The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
Console liga e só bipa nao inicia
meu console não liga, conecto a tomada e apenas não reage só um bip que vem de dentro ja fiz tudo e nada alguém consegue me ajudar com extrema urgencia?
My console doesn't turn on, I plug in the socket and it just doesn't react just a beep that comes from inside I've done everything and nothing can anyone help me with extreme urgency?
Hi!
Only a beep? Could be multiple things.
If you are lucky, it's just the power supply which is broken and need to be replaced. This would be a nice test too.
Guide: Xbox One S Power Block Replacement - iFixit Repair Guide
In the worst case, it's a motherboard issue. Could be the MOSFET or any other motherboard power related issue.
There are several beeps apparently coming from the source, being continuous and looking like a cricket very low sounds and zero sign of life.
Would try to replace the power supply first and see if that works! Otherwise you need to run some tests on the motherboard.
Juangb012 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 48
