The DualShock 2 Analog Controller first appeared with the Playstation 2 and featured only minor cosmetic changes in screw locations etc.
left analog stick is becoming increasingly squeaky
Hello,
My Dual Shock 2 is still working well after all these years! However, the left analog stick is becoming increasingly squeaky, and has begun to stick on rare occasion, but still functions near perfectly 99.9% of the time. Is there a simple trick to loosen the stick, and perhaps any buttons such as square and X, to prevent squeaking and sticking, using a household lubricant product such as WD 40?
Thank you,
Daniel McNamara
Hi Daniel!
First I would try to clean everything in there.
You can just use a wet cloth and clean it (make sure that the cloth is not too wet!).
For the stick, you could use ispropryl alcohol and clean it and see if that makes a difference!
If not, then you might want to replace the stick (worst case).
Please let us know how it goes and good luck!
D_mac08 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 76
