Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
help! new nintendo 3ds power problem
STORY TIME: A few years ago I accidentally bent the card reader's pin because it didn't want to read my Pokemon Omega Ruby gamecard. I thought the reader had some issue so I tried to clean it but I accidentally bent the pins. I must mention that the card reader didn't have any issue to read other games such as Pokemon X or simple DS games, so the conclusion is the Pokemon Omega Ruby got damaged for good. After this I disassembled my 3DS and tried to replace the gamecard reader, I ordered one online but it didn't want to work, so I sent it back, then I ordered another one and the same problem happened. After this I gave up and put it aside the New 3DS for years until today. So I ordered a new gamecard reader and it works, but I have other issues. The console itself doesn't want to turn on, not even the blue light shows up, however, if it is plugged in the charger, and if the orange light lights up then I can turn it on but only with luck. Sometimes the blue light shows up then before the system boots up, it turns off, sometimes I get lucky and the system boots up and the console works for limited time until it shuts off completely randomly. The most I could use it was like 20 mins after I turned it off, sometimes it only works for a few minutes. The second issue is the SD card. If the micro SD card is in, then I get the message that it cannot be accessed. I did format the micro SD card and I even tried with two other different micro SD cards but the problem still stays. The micro SD cards are one 16 gb and two 32 gb cards. I don't think they are damaged because my PC sees them and I can copy files on them. Also I measured my battery's voltage and it gave me 3.75V, so I don't think that the battery is damaged. Is it possible I have problem with the power board? Or is it possible that I have to change out the battery? And what do I do with the micro SD card reader? Does it need to be changed as well?
Hi!
So, the first thing really does sound like a battery issue.
I would get a new battery and see if this will fix it. Afterwards, try the micro SD card reader and see how it goes.
You already tried 2 known working Micro SD Cards.
Did you formatted them, the right way? > How to Format an SD Card or microSD Card (Nintendo support).
If yes, then you can try to replace that one and see how it goes.
Try a new battery first and see how that goes.
crwdns2944067:016crwdne2944067:0:
Thanks for the answer. I'll order a new battery and will try that. About the SD card, yes I did formatted them in the right way, I used that software which is linked on the Nintendo support.
My pleasure! Okay, let's see what happens when you replace the battery.
Alright, then most likely the SD card reader is broken and need to be replaced too. But let's see what happens if you replace the battery first.
New battery has arrived. Sadly, I still have the same power issue, so it looks like the new battery was not the problem. I am thinking of to get a new power board, maybe that's the problem.
Hi Klora! Ahw, that is dissapointing :(. The next step I would try is the power board as well and see how that goes. Sorry!
Also I must add that I still have problem witch charging, I mean even with the new battery when I plug in the charging cable the orange led only lights up for 5-10 seconds then off. I wonder if I have problem with the charging port or with the cable itself?
crwdns2934275:011crwdne2934275:0
Klora crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 130
