Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
Why does my laptop keep powering off by itself
My laptop constantly power off by itself. when i would try to boot it back up again it would somethings turn-off while booting up. So i'm wondering if this is a software problem or hardware problem
Many times this can be due to accumulated dust/dirt debris clogging the cooling fan intake/outlet and cooling fins, thus making the temperature rise to excessive levels on your cpu, motherboard, and other temperature sensitive components.
They are designed to shut down the computer at certain temperature limits.
The remedy, if it is due to this common accumulated clogging, is partial disassembly (often relatively easy) to get to the fan components and clean out the debris.
The dust/dirt debris accumulates just like on the air filter for your heater/air conditioner filter at home that you have to periodically change.
Several of my laptops experienced the same issue after years of use and cleaning out the clogging debris was the solution every time.
Often times is a hardware issue related to power. How does the battery charge level look like? Are you able to spy it before the system winks out?
Also have you tried connecting an external display as it might be an internal display issue, you'll also need an external keyboard and mouse as you'll need to run the system in clamshell mode for the external to be the primary display.
Julian crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 59
