The Lenovo ThinkPad L480 is a business-class laptop with processor options including Intel Core i3, i5, and i7 models. It was released in 2018.
Hi team... My Lenovo laptop l480 thinpad not powering on
Hi Sir's my Lenovo laptop L480 Thinkpad is not powering on..it just displays light in caps lock and power button flash for 1 second only..the fan aslo turns for 1second then stops... everything blank
This question was migrated from https://meta.ifixit.com/Answers.
Hi @yongamazibi
Try a full power refresh in case the BIOS has been corrupted for whatever reason and check if that resolves the problem.
  • Disconnect the charger (if connected)
  • Open the laptop, disconnect the main battery cable from the motherboard and then disconnect and remove coin cell RTC battery from the motherboard.
Here's the hardware maintenance manual for the laptop that will help. Go to the bottom of p.75 (81 of 112 pdf) and p.77 (83 of 112 pdf) of the manual, to view the procedure to disconnect the main battery cable and to remove the RTC coin cell battery, respectively.
Note: Once the RTC coin cell battery is out, measure its voltage. If it is <2.5V DC or if the battery is >4-5 years old, replace it. If it needs replacing, search online for 02K7078 to find battery suppliers that suit you best.
  • Press and hold the laptop's power button for a full 30 seconds and then release it.
  • Reconnect and reinsert the RTC coin cell battery on the motherboard, reconnect the main battery cable, reassemble the laptop, reconnect the charger and check if it turns on OK etc.
If it does there may be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset back to its factory default condition by the above procedure. Once the date and time have been corrected, the message won't appear the next time that the laptop is started. If there were any user definable BIOS settings changed by you to suit whatever operating requirements you needed, they will have to be changed back again also.
You may just need new cord if not take to repair shop may not be worth fixing
if the problem was with the cord, fan and leds would probably not power up
In my experience, if fan turns up and then powers off and nothing on display, only leds shortly on:
Most likely problem: memory or CPU
Start with removing all memory and reinsert just one memory module and try booting again
if still not booting: try to boot with every memory module separatly to find out which one is broken and which isn't
if the problem remains with all memory modules: most likely cause: CPU problem
Well Try a hard reset by unplugging the power adapter, removing the battery, and holding the power button for 20 seconds to drain residual charge. It might help you in fixing the issue if you did not try this please try it once.
Yongama Zibi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 172
