The Asus X515 is a series of entry level laptops released in 2020.
Laptop won’t turn on despite being plugged in
Only a black screen, the battery charge indicator blinks white while the power indicator is just steady white then after a few more blinks from the battery charge indicator it does not light up anymore. This also only happens when my charging cable is plugged in.
When the charging cable is not in when I try to turn it on the power indicator does not light up at all.
@sothebies from what you are describing, you have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the connector is not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc. Use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Use a video like this to get into your computer. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question
Sothebies crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 214
