Repair and disassembly guides for hundreds of optical disc drives.
Repairing optical drives instead of just replacing
Does anyone have advice for repairing optical drives. I have one that sometimes reads a disk but if I try to burn a disk I get errors. I work in an e-cycle plant and we get quite a bit of them and repairing seems like a better option than just replacing.
This question was migrated from https://meta.ifixit.com/Answers.
@jerrywitherite most common failure for something that you describe would be a weak laser. Sometimes increasing the voltage to the laser slightly by adjusting the trimpots (never do that without a meter or you could burn it out). Ultimately replacing the laser would be the only real fix.
they are so cheep. throw it away and try another.
@altonbell40070 the iFixit community frowns upon throwing stuff out just because "they are so cheep". Check on here https://www.ifixit.com/Right-to-Repair to see what this is all about.
Charge problem
Jerry Witherite crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 68
