Repair and disassembly information for Google's Pixel 7 smartphone, released in October 2022. Identified by model number GVU6C and GQML3.
Software problem or Hardware problem?
my pixel 7 have got some hanging issue like power button doesn't work properly if i press the power button then phone did restart so after that i backup all the data and did the factory data reset but after this my phone does not work and only i can see the google logo and restart again and again and only i can do is open fast-boot setting nothing else also if i choose between them then again restart problem what should i do
It sounds like your Pixel 7 is stuck in a boot loop after the factory reset, which can be frustrating. Here are a few steps you can try to fix it:
  1. Perform a Forced Restart – Hold the power button for about 10 seconds to force a restart. Sometimes, this can help break the loop.
  2. Charge Your Phone – Ensure your device has enough battery. A low charge can sometimes cause boot issues.
  3. Boot into Safe Mode – If possible, try booting into Safe Mode by holding the volume down button while restarting.
  4. Try Recovery Mode & Clear Cache – Boot into Recovery Mode and select Wipe Cache Partition. This clears temporary files that might be causing the issue.
  5. Flash the Factory Image – If none of the above work, you may need to flash the factory image using a computer. This is an advanced step, but it can restore your phone.
If your phone is still stuck, you might need professional repair or contact Google support for further assistance. Let me know if you need help with any of these steps!
Still Not working my Bootloader is locked and OEM is also not unlocked what can i do now ?
@nishantkuma2956 I wouldn't count on any more help from Ziyaad. His answer is obviously AI generated and follow-ups aren't exactly in the AI bag of tricks.
@dadibrokeit if you know how to fix this dm me for the further communication ig:@n15hhuu
@nishantkuma2956 I'm sorry but I don't have any suggestions for fixing your phone; at this point it does sound like a hardware problem but I'm not seeing any clues pointing to what might be causing it. I mainly wanted to let you know that the original answer here is likely all you are going to get, as the writer most likely entered your question in something like ChatGPT and just posted the answer here, so it's doubtful they have any further insight into your issue.
Also, we prefer you don't ask for individual help by posting contact information. First, it opens you up to getting on spam mailing lists, and second by taking your discussion off the site, you deprive others of any learning you might receive. Since helping everyone is the goal of this site, that runs counter to their mission.
@dadibrokeit thanks for the information but i want to repair my phone i have brought it secondhand from the market but i think its software issue because i can open fastboot option easily but i cant do anything above this because if I choose between fastboot option the phone again restart and only google wordmark logo appears is there something i can do by my own laptop ?
Nishant Kumar crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 22
crwdns2942667:0crwdne2942667:0 31
