2002 Lancer CK5A Window not reciprocating
I've bench tested the regulator and it's working. The switches driver window relay clicks in both switch directions yet the window still doesn't move. I'm open to any ideas or wiring diagrams.
Cheers team.
crwdns2944067:04crwdne2944067:0
@andrewmorg21490 "bench tested the regulator " is that including the motor? Besides clicking, have you checked the relay?
Yeah, motor works as it should. Moves the cable up and down on its path. I'll take the switch apart and come back.
The "auto-sw" arm was in the wrong position making the switch not work at all. I'll put it all back together and see if it stays fixed 🤣
Looks good and works good. It's a silly little 3mm plastic tab the switch is meant to hook on to. Out of all things...
It's a little ~3mm plastic tab the switch is meant to hook on to, and it should be aligned with the outline on the PCB.
crwdns2947821:0crwdne2947821:0
Andrew Morgan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 42
