The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
New 3DS XL charging but not turning on
As you can see in the video it does charge but when i try to turn it on it flash the light red and doesn't turn on.
I already checked the fuses and they work
edit:
drift problem
edit:
new problem where i have to put pressure on the motherboard
Hi!
Most of the time it is caused by a defective power board.
Did you tried another battery first? Maybe this will work. If not, replace the power board and see how that goes!
If you need any guide, please let me know!
crwdns2944067:010crwdne2944067:0:
Hello, I've already tried replacing the battery but no change unfortunately.
I guess i'll try with a new powerboard.
Will report on how it goes when it arrives.
Alright! Thanks. Please keep us posted and good luck with the repair :)!
@dan0 Hello again, so the part arrived i put it in, now it shows the blue light but the screens are both black and with no sound.
Hi!
Alright, 1 issue fixed! The other issue you are describing could be caused by a lot of components. Please check if everything is connected as it should! Also, check if none of the cables are damaged! Sometimes this is caused by a bad camera cable. Please tripple check them!
So i've got it tu fully turn on, i think the red cable next to the charging port wasn't in all the way.
Now it works but it looks like the circle pad (the big one) doesn't work and it goes right all the time (can add a video to the original post if needed).
Should i replace the whole part or is it fixable?
ty for the help btw!
crwdns2934275:05crwdne2934275:0
Astronyu crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 77
