Guides and repair information for cars and SUVs manufactured by Kia Motors
Turn off my car
My car model is Rio 2008.
The dashboard light is not on. The diagnostic device did not show any faults.
The radiator water circulation pipe to the engine was fouled. The clutch cable was adjusted. At low speed, when downshifting, the car turns off, but the power behind the amp does not turn off.
If the engine shuts down, you are loosing ignition power. It is possible it is just power to the ignition coils. You may be able to determine this from your dash. Different things light up if you are only on accessory or on full ignition.
The downshift causing this is most likely causing movement of a wire or connector, breaking the connection or shorting it out.
Start with the dash observation. If it is not a full ignition shut down, inspect and reseat spark coil wiring and connectors.
If it is a full ignition shutdown, look for loose fuses or intermittent/loose relays, or damaged wiring.
Neda crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 32
