How to repair a screen senser fillament
screen sense fillament
I realize this may be partially attributed to language translation, but it's not clear from your question what it is you're looking for. Do you have a broken flex cable going to some sort of sensor mounted on the screen? If so, which sensor is it? How is it broken; is the cable itself damaged, or is it a connector issue?
Pictures are often worth a thousand words, so if you can add a photo of the damage you're concerned about, that would help.
Adding images to an existing question
The more descriptive you can be about your problem, the better chance we can help. As it is, there's nothing we can do with what little explanation you've given us.
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 7
