Flickering TV, lines on the bottom
Hey,
My TV shows a flickering screen with multiple lines. At first some minor flickering occurred and from use to use it worsened. At current state no usable image is recognizable. I opened it up and checked all Connections and also tested, if the backlight was the issue. Non of that fixed my problem. I ordered a replacement PSU board und the TV seemed to work fine again. After about 30min of use the original problem occurred again. I also tried a new mainboard afterwards and nothing seems to fix my issue.
Well, you have tested the obvious, connectors and backlight. However, the backlight wouldn't cause lines on the screen. You have 3 components on the TV, not counting the speakers. You have replaced 2 of them.
Assuming the replacement parts are fully functional, there is not much left but the panel.
But what explains the functionality for 30min after replacing the PSU?
Jonas Herrmann crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 15
