Repair guides and support for Canon's EOS Rebel XSi. This is a DSLR camera with a 12.2 MP sensor released in 2008. Also known as the EOS 450D and the EOS Kiss X2.
Was slightly working now not at all.
I have just got this camera from Facebook marketplace.
When I met with the seller, upon powering it on, briefly the camera settings (such as ISO and Shutter Speed) could be seen in the viewfinder, however the LCD stayed black. The flash too would work during this time.
Everything that was working:
  • Camera Settings in the viewfinder
  • Flash would actuate, not actually flash
  • Auto-focus
Things that weren't working:
  • Camera mirror
  • LCD
I followed the guide to replace the LCD but instead of replacing it, I unplugged and replugged the screen. When assembling it all again, I now have nothing showing, in the viewfinder or LCD. The flash is now no longer working.
Everything now not working:
  • Flash Actuation
  • Camera Settings
  • Auto-focus maybe??
  • Everything that wasn't working originally
I should also mention I have tested that the lens recieves power with a multimeter. I also checked the LCD and it recieves ~4.5V on what I assume is the main power line for it, other components recieve 3.3V and 1.8V. I have checked the battery too and am getting 7.4V+.
I am not too sure where to look now and would like some pointers on where to look next. In the meantime, I will probably end up tracing all the circuits or checking the viewfinder display to find why that stopped working.
Updated: Things Checked/Done:
  • Unplugged and replugged all cables on the front panel.
  • Checked every capacitor/volatile component.
  • Unplugged and replugged all cables to the motherboard, during this found that the on/off switch ribbon was almost out.
  • Manually actuated the flash and mirror gearboxes, they reset (and scared me) when reassembled and powered on.
  • Tried two different batteries, both fully charged.
  • Tried with and without SD card.
Thank you for your time.
What is the battery voltage supposed to be (what is listed on it)? Is there a way to power the camera via a USB cable or some other external source? If it's a lithium battery and is at all low, it is not charged as lithium don't drop voltage as they are used the same way nicad batteries do. So if the battery is rated at say 7.6V, 7.4V would mean a battery not charged and you may see it drop under load. I have not tried to open up a DSLR\Mirrorless camera so I can't tell you much about the inside.
The listed voltage on it is 7.4V, I don't have the correct cable and am looking to get one as it is a usb type b mini. (It is also easter Sunday so no where is open at the moment)
Snap Second crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 66
