The Acer Aspire 3 A315-58-350L is a revision of the Acer Aspire 3 budget laptops. They are intended for the common consumer market such as college students and on-the-go employees who need a lightweight laptop.
How do you fix the charging port
I need to know how to fix the charging port
could you please make a guide or video showing how to fix the charging port
Step 1: buy a replacement charging port (The soldered on charging port is correct)
Step 2: take out the motherboard
Step 3: strip the motherboard (No removable ram, no ssd, just the empty board)
Step 4: locate the charging port and wrap the surrounding area
Step 5: use a hot air station (or soldering iron) to remove the port
Step 6: resolder the new port (make sure it aint loose)
Step 7: charge test
If it works, go to step 8a:
If it doesnt, go to step 8b:
Step 8a: reassemble
Step 8b: reavaluate, figure out what you did wrong, then go back to 8a
Step 9: test again if it boots or not
Voliá
Farmaan Paracha crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 154
