Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
PS4 Pro wi-fi not connecting
I have a PS4 and a PS4 Pro. The Pro does not connect to wi-fi. I get code errors saying "can't connect". I have tried changing DNS codes, etc. all no good. It connects fine w/ an ethernet cable. I have reset router, etc. Other point is that the PS4 connects to wi-fi just fine. So the network settings must all be ok.
I think there is a physical problem with the wi-fi module. I understand this is not a replaceable item. Is that correct?
Can I connect some kind of external Wi-Fi adapter to either the ethernet or USB port?
Any help would be appreciated. Thank you!
Hi @chazzlav
Try using the console's WiFi as close as possible to the home network router i.e. <15cm and check if it detects, connects and maintains a stable WiFi connection.
If it does it may be an antenna problem in the console i.e. loose connection or faulty antenna.
Unfortunately I cannot find a video or guide that shows where the antenna is connected in a PS4 Pro but here's the ifixit PlayStation 4 Wi-Fi Antenna Replacement guide that may hopefully be of some help.
Chazz Lavely crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 55
