Find repair and more information about the LG LFCS27596* refrigerator, a 2019 model featuring automatic defrost without through-the-door dispenser or ice maker. This page covers information for model numbers matching the pattern LFCS27596*.
CF E code after fan replacement.
I replaced the condenser fan on my fridge when this code popped up. It worked fine for like 24hrs then I noticed the sides of the fridge were hot again and it was throwing the code as well. I unplugged it and let it sit for about 10 minutes then plugged it back in and spun the fan my hand and it started working again. Now it is off again when I checked it about 16hrs later. Any ideas on what would cause this because I am out of ideas. Thanks for your time
Hi @dylanmcguire
A CF E error code indicates a problem with the condenser fan or condenser fan operate circuit.
Here's the start of the CF E troubleshooting section of the service manual that may help.
It the replacement fan is the problem, search online for EAU63923602 to find suppliers that suit you best. This is the part number for the condenser fan and it should be printed on the fan itself if you wish to verify that it is the correct one.
crwdns2886500:0Ensures optimal airflow across the condenser coil in LG refrigerators by rotating when activated.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
LG Dc Motor Assembly - EAU63923602
$93.99
Dylan McGuire crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 852
