2011 iMac CPU Upgrade 4 LEDs, Chime, No display
Hello,
Hopefully I'm not over looking something, I've done iMac upgrades in the past and been very successful, but this one has stumped me.
I have an 2011 iMac that does work with the original i5 CPU, I can get into OS X Lion, look at the screen etc so everything is working there, but when I upgrade the CPU to a i7-2600s, I get no display, the 4 LEDs are on so I know that not an issue and connecting external display shows me Lion but the main display stays off.
Going back to the i5 gives me the main display again, but going to the i7 doesn't, I've rebuilt several times now, I know there's issues with the non S 2600 but that's not what I bought and I double check the CPU code and in Lion,
When I get a chance I'll replace the CMOS battery but what could be causing the issue? Would buying the non-S 2600 solve my problem?
Thank you
The 21.5” iMac’s use the Intel iGPU logic within the CPU chip. Here’s the systems specs with the Apple supplied 3.4GHz i7 (2600 S) chip so you have installed the correct chip, as you put back the i5 and the display problem went away it’s likely the i7 chip is bad! The only other possibility would be the display cable tugging on the logic board connector so the display cable data connection was not stable.
I bought another i7-2600s from a different platform and seller and will report back on how it goes
Hello, I just installed another i7-2600s after confirming the CPU name, I am getting the same result, could the GPU be incompatible?
Thank you
@giosoto - Are you sure you have installed the CPU in the correct alignment?
There is no separate GPU chip in this series, even still the dedicated GPU used in the 27" wouldn't be an issue between the i5 Vs the i7
Gio Soto crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 66
