The truck has a new exterior profile taking styling cues from the 2014 model year 4Runner SUV and the 2014 model year Tundra pickup and features a much more aggressive and masculine look, with a larger grill and new projector beam headlamps.
Why don’t my headlights turn off on auto
Headlights will turn on with auto setting on headlights switch but will not turn off
As stated in question on auto they turn on when it’s dark like early morning but do not turn off once it get light/sunny out. Thanks
Ahh, I thought you mean when the car shuts off. Do you have anything covering the sunlight sensor on the dash? If not, check into that sensor.
Auto headlights usually have a timer. After you shut the car off and exited, you can use the key fob to lock the car twice and that should override the timer; this will usually also beep or activate the horn briefly. On some vehicles, you can go into your settings and adjust the timer
Hi @markduane
Check that the headlight light sensor, located on the passenger side of the dashboard (see image) is not covered or dirty, preventing it from detecting when it is light enough not to have the headlights on.
mark duane crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 48
