Mengapa HP saya tidak bisa hidup lagi
Translation Indonesian - English
Why my phone won't turn on anymore
Does the phone charge up? Did you drop it? Did you get it wet?
Do you have a local phone repair shop? I think you need to visit them.
@muhammadab39789 you are not giving us enough information. You need to consider to letting us know if anything happened to your phone. we will need to know if this just happened for no reason as well as what you have checked and what you have tried to fix it.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc. use a few puffs of compressed air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get an ammeter and see if your phone draws any amperage from the charger.
Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you don't get that voltage check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it. Your phone has a separate power board that could be faulty, consider replacing that.
Since iFixit does not yet have a guide for this specific phone, use something like this video to work on your phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@muhammadab39789 Anda tidak memberi kami informasi yang cukup. Anda perlu mempertimbangkan untuk memberi tahu kami jika terjadi sesuatu pada ponsel Anda. Kami perlu tahu apakah ini terjadi begitu saja tanpa alasan dan apa yang telah Anda periksa serta apa yang telah Anda coba perbaiki.
Pertama, Anda perlu memeriksa catu daya Anda. Pastikan catu daya memiliki voltase yang tepat. Periksa untuk memastikan konektor tidak bengkok, dsb. Setelah itu, periksa port pengisian daya. Bersihkan dari segala kotoran, dsb. Gunakan beberapa semprotan udara bertekanan untuk membersihkannya. Pastikan tidak ada korosi, kotoran, dsb. yang menghalanginya bekerja. Jika tidak ada yang berhasil, ambil amperemeter dan lihat apakah ponsel Anda menarik arus listrik dari pengisi daya.
Ukur voltase pada konektor baterai Anda dengan pengisi daya terpasang. Anda harus mendapatkan sekitar 4,2V. Jika Anda tidak mendapatkan voltase itu, periksa kabel fleksibel yang berasal dari papan pengisi daya. Pastikan terpasang dengan benar dan tidak ada sobekan atau kerusakan lain di atasnya. Ponsel Anda memiliki papan daya terpisah yang mungkin rusak, pertimbangkan untuk menggantinya.
Karena iFixit belum memiliki panduan untuk ponsel khusus ini, gunakan sesuatu seperti video ini untuk memperbaiki ponsel Anda.
Saat Anda memperbaiki ponsel, ambil banyak gambar. Setelah selesai, ambil gambar tersebut dan buat panduan untuk iFixit. Itu akan membantu orang berikutnya yang memiliki perangkat dengan masalah yang sama seperti Anda. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai ini.
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 60
