How to change brake pads 2008 Nissan skyline 370gt
change brakes 2008 Nissan skyline 370gt
Are you looking to do front, rear, or all? The process is about the same for most of them, except for brembo style brakes. Make sure emergency brake is on securely. Jack up the car on one corner on the pinch weld and put a jack stand beneath it. Remove wheel. Remove slide pin bolts and slide caliper off. Remove brake pads from the caliper bracket. Remove caliper bracket. Then remove machine screws if present and you may need to strike the rotor with a hammer to knock it free of the hub. Swap on new rotors, clean up caliper bracket of rust build up/ lubricate slide pins and apply new shims; reinstall. Slide brake pads in (pad with wear indicator goes on the back, and when you remove pads pay attention to orientation of the wear indicator, if its top or bottom). Make sure pads move freely. Compress caliper piston (using the old pad and channel locks should work find, if it is a spin style caliper, characterized by a parking brake cable and notches in the piston that line up with notches on the rear pad, you will need to get a brake disk kit or brake cube). Slide caliper over pads and secure slide pin bolts. Make sure caliper moves freely and reinstall wheel. Front calipers can just be compressed. If it has multiple pistons, using the old brake pad and using channel locks in the center may be difficult, but should get the job done, or buy a ratcheting piston compressor
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 28
