The second-generation Durango was first shown as a concept dubbed Dodge Durango R/T concept at the 2003 Detroit Auto Show.
So confused any help appreciated
Kinda long...
I have a 2006 Dodge Durango "Rango" 4.7l 4x4
I am the second owner and have had it for 12 I/- years has ran fine (changed a few parts but has been on there since 2006)
Our house caught on fire Nov 11th end lost everything even the key to Rango. My daughter has 2 keys made on the spot. Had to jump it off but started right up and ran just fine for 5 or so hours. Had to get a jump and when started back up ran rough (like jumped time)
Found that it is only hitting on one side (1,3,5,7)
Replaced battery, spark plugs, the cam shaft, throttle, air intake and mass airflow sensors nothing still running bad.
It does start (but hard to) it does run but has no power (probably because it's only running on 4 cylinders 😆)
Any advice is greatly greatly appreciated 🙏
Do you have codes for a check engine light? If bank 2 isnt firing at all, you could have a bad upstream 02 sensor. You can do all battery reset for 5 minutes and see if it fires for just a few seconds since the battery reset will clear you store fuel trims data. If that doesnt change anything, id do a compression test across that whole bank and compare to the side thats running normally. If low or no compression on that bank, id suspect a timing issue (I see that you replaced camshaft, but if damage was done prior to replacement, that cant be undone by resetting timing)
Michelle Young crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 50
