Service on my QDJ06
About how much would it set me back to get my QDJ06 serviced?
@yeseniasep67448 that will totally depend on where you are located and if this is still use for any kind of patient care. If so, you know it will get expensive because of BioMed regulations etc. In theory, you can only use those that are "certified" to work on this type of equipment. If this is not used for patient care etc. You could get this fixed by any decent HVAC technician or general electrician. You could probably even do it yourself. After all, iFixit is trying to empower YOU to fix your own devices :-)
@yeseniasep67448 here is the Dual Compartment Assembly, Internal Parts - 18" explosion drawing.
#3 is the bottom heater. All you would need to do it is to remove the 2 screws in the front and then pull it out, disconnecting the wires as you are removing it. If you can, take a couple of well-focused images and post those with your Question. That way we can see what you see. After that we can even guide you on how to check the heater and the fan.
Also, not an SM, this should help. BioMed persons suggest that all that is need is to remove the two screws from the front. Further explosion drawings for your heating cabinet are available https://partcatalog.steris.com/ACD/deliv...
Oh. I'm a massage therapist. I want to use it to heat up towels and hot stones. I would like to fix it myself. I bought it used, I saw it was working, however when I got home I realized the bottom cabinet wasn't heating, and it smelled bad. Kind of like pancake syrup.
I live in South Houston, TX.
@yeseniasep67448 this "it smelled bad. Kind of like pancake syrup." Is usually caused by a bad heating element. Bottom elements catch a lot of dust, debris etc. and all that gets caked on this. Read through the warming cabinet maintenance guide which you can find under the Documents heading on this page Steris AMSCO Warming Cabinet
I'll talk to my BioMed guys tomorrow and see if I can get the one for your specific model. Let's see if we can't get yours fixed.
@oldturkey03 Thank you! 😊
I apologize, were you able to find a guide for the steris qdj06?
crwdns2942667:0crwdne2942667:0 444
