An all-new Passat, based on the Volkswagen Group B5 platform, was launched in 1998 in North America.
Charging problems with battery
My battery won't charge
@shirleylar63859 let's start off by clarifying what you have checked. Have you checked your battery? Have you checked your alternator? Use a voltmeter and measure the battery voltage between the positive and negative post. It should be around 12V Next, with your Passat running measure the voltage between the positive and negative post. What voltage do you get (expected is around 13.5V to 14V DC). If you have that voltage, it is most likely your battery. If you do not have that voltage, it could be your alternator. Let us know what you find out.
well, you must start by doing something and letting us know what you did.
Your question is like my car won't run. What's wrong?
Start by taking it to AutoZone or Advance Auto, They can check the battery and alternator.
That alone will likely get you an answer.
Shirley Larson (Squirrel) crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 21
